Gasket set
Gasket set
I'm pretty-sure I'm going to go with the SE Cam tensioner kit for dealing with any future problems in that area. The HD#17045-99D rocker box gasket kit: every gasket needed in it? I know how it is with gasket kits. You either get more than you need or the kit doesn't really have all gaskets needed....it's that way with car/truck 'kits' anyway....
Thanks
(I have no idea why there is a pic of Blue Harley following me around. It ain't mine and I didn't put it on anything)
Thanks
('Cquse me. Why do wierd photos keep showing up on posts? Dislike that)
To answer your original question, 17045-99D will have all the gaskets and bearings, along with upgraded breathers. About the only thing I would add (that doesnt come in the kit) would be the Torrington B-148 inner cam bearings. The only other thing you might consider would be adjustable pushrods. If you do a cam swap while your in there, and select anything other than SE, the adjustable pushrods are a requirement. Theres just enough of a difference in the heel of the lobe on aftermarket cams that stock pushrods wont properly center the lifter piston.
Speaking of lifters, go ahead and replace them while you in there. They arent all that expensive. And I'm going on the assumption you know how to inspect the cams...
I actually began to think about using the EZ Start S & S gear driven cam, since I would eventually like to upgrade to a 103" and this would provide ACR's, but changed my mind after talking him.
I really didn't want to replace my stock push rods with adjustables, since I understand new aftermarket push rod tube should be used for additional clearance needed for adjusting them. I don't know this to be a fact, but advice I read about for installing adjustable push rods. I need to check my breather system filters and valves due to excessive a/c oil blow-by, so I have no other reason to spend the additional money for adjustable push rods with new tubes, since I'll be removing the valve covers anyway.
This recommendation to replace the push rods and lifters causes me to re-examine my original position, since my 2009 RG has 37k mostly highway miles. It maybe a good time to at least replace my lifters, but I still cannot see the adjustable push rods.
Ronster
