I'm a big fan of this mod. As for the belt length, here's info from Andrews. I guess it depends on how much adjustment you have remaining at the axle. I was fine on my install. I have the tools required to make this change. Send a PM if you're interested.
From Andrews;
Installing a transmission pulley with more or less teeth than stock requires adjusting the rear axle forward (for more teeth on sprocket) or
backwards (for less teeth on sprocket).
Rear axle position adjustment for each one tooth change on transmission sprocket = + / - .125 inches (3.2mm).
Rear axle position adjustment for each one tooth change in belt length = + / - .280 inches (7.1 mm).
If there is not enough axle adjustment at the rear frame, it may be necessary to use a belt with more or less teeth than the stock belt.
Damn, you got a nice bike on the way.. I love WG's. What color scheme?
this one rocks..
find it at H.d.r.i.d.e.r.s.u.s.a....com
The one I'm looking at is much the same as this one even down to the pipes. Black with a small silver stripe around the tank and fender, only the front end doesn't have black lowers and triple trees, or tall risers. I'm hoping this guy doesn't change his mind over the weekend.
