thunderheader at 250 miles
Old Jan 21, 2012 | 07:06 PM
  #31
JCleary's Avatar
JCleary
Originally Posted by Mike650
decided to go with Vance and Hines fuelpak.
If you can, return it or cancel your order. Get at least a Power Commander V, or better yet some kind of downloader like a TTS Mastertune or SE tuner.
The Fuel Pak is not very good. You can't tune a bike with it. You can only select preprogrammed maps from Vance and Hines. My buddy had one, and it never ran correctly, even though he was using V&H components. After multiple calls to V&H he yanked it off and went with a SE program.
Old Jan 21, 2012 | 09:24 PM
  #32
Mike650's Avatar
Mike650
unfortunately TTS doesn't have a program for my bike. their the first ones i checked. and i forgot about the power commander. thanks for the heads up. im going to try and cancel my order and get the power commander.
Old Jan 22, 2012 | 01:38 PM
  #33
Twigg's Avatar
Twigg
+1 on the PC-V . Also consider running a quality Full Synthetic instead of a blend. Amsoil, Redline,etc. Syn3 is actually a blended synthetic.
Old Jan 22, 2012 | 04:41 PM
  #34
Mike650's Avatar
Mike650
well i cant cancel my order and the payment already went through..... so im going to give the fuelpak a shot and see what happens. and RE oil, i was thinking about running redline in the motor and the syn3 for my primary and trans. any objections to that? good idea, bad idea?
Old Jan 22, 2012 | 06:19 PM
  #35
babyray's Avatar
babyray
Gary Bangs shop refused to install a Thunderheader period, said they weren't "comfortable doing it due to inferior quality. Been on for 35000 plus miles, no problem.
Old Jan 22, 2012 | 10:24 PM
  #36
JCleary's Avatar
JCleary
I don't like Syn3 at all in the primary. It makes the clutch grabby when hot (at least that's my experience).
I prefer either stock Harley Formula+ or Redline primary fluid. Either one works really well. Smooth engagement, which I like.
I've been running Redline in my bagger since 5k miles in all three holes, got like 24k miles now. The shock proof heavy makes the tranny shift hella smooth. It's good stuff. The oil samples I have sent off to Blackstone have all come back good, so I can honestly vouch for the Redline 20w50.
Old Jan 22, 2012 | 10:26 PM
  #37
JCleary's Avatar
JCleary
I've had my black one for over 20k miles, no problems. I bought a chrome one for my Dyna, and don't expect any issues there either.
Old Jan 22, 2012 | 11:55 PM
  #38
Mike650's Avatar
Mike650
you run the redline synthetic 20W50 in the trans?
Old Jan 23, 2012 | 06:43 PM
  #39
jisananimal's Avatar
jisananimal
so the dealer said i should wait till break-in is done before changing the pipe, but if i change it now with the bike about half way there, would it hurt the break-in of the motor? or would it help?
did u go 2 duddley bro?? i slapped my on v&h comp pipe when i bought the bike...they sed it shouldnt have any issues
Old Jan 23, 2012 | 07:33 PM
  #40
JCleary's Avatar
JCleary
Redline Shockproof Heavy. Looks like Pepto Bismol and stinks bad, but it works great!
