Dyna power tie in for radio
I have a 2012 Wide Glide and I am also looking for a keyed power source. Unless I am looking in the wrong spot I cant find the four pin connector under the seat. Did this change for 2012? If so, where can I tie in for keyed power source? I tried using the wires for the license plate light but I get feedback through the speakers when I use the turn signals.
Thanks for any help.
hite and yellow are both switched wires and useless for connecting a radio.
I'd stick to the options I posted previously.
What kind of radio are you setting up?
I have a set of handlebar speakers that hook up to a simple small amp. I powered that puppy up with a "add a fuse" inside the fuse box. Super easy to use and doesnt involve any hacking or having to purchase costly wire harness adapters.
I have a 07 FXD, I just ran the wire from the amp OVER the tank (under the console) then down into my fuse box under my seat.
The add a fuse was purchased at my local advance auto parts
Thats not a bad idea...
i run a boss audio
Right now i run it directly from the battery but i kinda want it on the ignition..
Plus, will never use my bike radio for tunes while it is parked. I have a million (my wife counted) other bluetooth speakers at home I can use for that purpose. lol
