Dyna Wide Glide Oil Change Help
Hey guys Im helping a female friend out who is a little tight on funds in changing her fluids this week prior to long ride she has planned next month. She has a 07 Dyna Wide Glide and Im not sure the location of the drain plugs on Oil, Tranny and Primary. I am very familiar with Touring and Softtail models but have never personally serviced this style of Harley. I know she should have a service manual as I do but she doesn't so any help would be greatly appreciated. Also just want to confirm 3 qts oil (2.5 qts wet), 1qt tranny and primary). Thanks again!!!
1 Attachment(s)
Here you go, this is the pan under the bike. Look underneath and you can't miss it.
Attachment 534300 For the primary drain, start at about the center bottom of the derby cover and look under the primary cover. Correct on the amounts. |
awesome!!! Thanks!!! that helps a lot. I assumed the Primary is the same on all 07 and later models. thanks again Pig in a blanket!!!
Yes sir, glad to help since so many have helped me on here.
1 Attachment(s)
thanks knots! ya same place on all the 07's. So do I have the right oil quanities then?
2.5 qts oil (wet) 1.0 qt. primary and tranny??? |
Yes those are the correct amounts.
© 2024 MH Sub I, LLC dba Internet Brands
