The Plasti-Dip Thread
#584
ABQ-Jammer (07-12-2018)
#586
Need to reread this thread but....do they make a 'clear' one can use to simply cover/protect a existing paint?
don't want to 'color' the bike differently. need to dig some but thought I'd throw this up quick.
I called Dip your Car and she quoted all kind of products needed to do this (cleaners, primers etc). Sounded super complicated....but it can't be that hard. I think she was reading a script.
#587
Can I apply Plasti Dip® Glossifier over non-dipped areas?
Glossifier can be sprayed over non-coated areas to add a glossy finish. And it also will peel off afterwards, just like regular Plasti Dip®. However, because Plasti Dip Glossifier is specially formulated to bond with the unique chemical structure of Plasti Dip coatings, it’s not generally recommended for other surfaces.
They also sell one call Sanitizer to make things Satin
The following 2 users liked this post by kcfocust:
ABQ-Jammer (07-09-2018),
F150HD (07-09-2018)
#588
So, is this Plasti-Dip stuff similar in composition to that Flex-Seal stuff; basically a spray-on thin rubberized coating? I'm still thinking about spraying this stuff on my dash, since I get blinded by the chrome almost every day going home, and want to stop that, and if I can add more black to the bike at the same time, I might do the same for other parts, like my chrome crash bar and spotlight housings and risers and maybe backrest bar and fender rails, too. I like my black bike, but I also like a little chrome accents, so I won't totally black it out, but want a little less chrome, and can't afford to buy new black parts for much of the bike.
For those that have already done parts, like the pullback risers, would you also let me know how much it took to do those parts, and how many coats you put on?
Also, how many coats would you suggest for the dash, and how many cans would I need to do that?
#589
1st coat should be a very light coat, maybe 50% coverage
2nd coat should be close to the same as 1st
3rd coat can be a little heavier - should be 100%coverage at this point
4th and 5th coat should be very heavy, wet coats
Make sure to let it dry about 15 to 20 minutes between coats. Also, keeping the can in a jug of hot water helps with the spray
ABQ-Jammer (07-12-2018),
F150HD (07-09-2018)
#590
