WON't START
03 FXD, 95,000 miles...Cranks no spark, replaced plugs, wires, coil, and ignition module... still no spark any suggestions.
And it is getting fuel. |
Check for codes: http://www.ehow.com/how_5556684_pull...-davidson.html
I'm assuming you've checked all the fuses and they're good? |
Crank position sensor.
Disconnect it & put a volt/ohm meter across the pins at connector. If resistance is infinate, that's it. As I recall (same thing happened to me), should be about 300 ohms. BTW, no codes were set when mine failed ('04 Dyna). Edit: Sorry, my mistake. In checking my records, the new CKP sensor checked out at 948 ohms resistance, not 300. |
| All times are GMT -5. The time now is 01:56 PM. |
© 2026 MH Sub I, LLC dba Internet Brands
