What type of oil are you using?
#41
#42
I'm new to the forum but not to bikes. Oil is the subject of more differences of opinion than politics! It is fun to scroll through and watch the information fly.:-) I have seen and heard almost every combo of oils used, and I agree with anyone who says just make sure you keep up with your oil/filter changes and all will be well. I can't remember the exact quote but Cycle World had a research project a few years ago about oil and it was something like 0.08% engine oil failures in the test category, basically damn few failures occured when regular oil/filter changes were made...I am thrifty, my wife says "cheap", but I use regular oil for all except the tranny in which case I run gear oil, usually Rotella, but I can't say it's any better, but it doesn't break the bank for sure.
#43
Nemosengineer (06-24-2017)
#45
#47
Same as Yamaharley above for me
I went from fully synthetic back to dino as I find its a quieter engine. Change that oil every 2500 mies.
10w40 synthetic motorcycle oil in the primary and Shockproof pink goo in the transmission and change those once a year.
I'm not brand specific, just whatever is reasonably priced at the time.
#48
Well, a necro thread is resurrected, so why not
Dyno in the engine for me; use synthetics and the top end sounds awful, even through ear plugs. Valvoline VR1 SAE 50 in the engine, Mobil 1 Racing 4T 10W-40 synthetic in the primary, JASO rated, and Mobil 1 75W-140 synthetic gear lube in the transmission. I've used Redline V-Twin transmission w/shockproof in the transmission but I like the Mobil 1 better.
Snicky smooth two finger pre-loaded upshifts and two finger rev-matched downshifts. Just keep that clutch pack and clutch cable freeplay adjusted
Change engine oil frequently, every 2 -2.5k, primary and transmission every other change...
#49
