New rider, got a question.
Old Jun 29, 2012 | 10:44 PM
rgrsnell21's Avatar
rgrsnell21
Exclamation New rider, got a question.
Hoping someone here might be able to help. Just bought a 2009 Street Bob. I was going down the highway at about 45 and the bike started sputtering and backfiring. After the backfire there would be a loss of power, then it would lurch foreword. Did that about 4 times then flat out shut off. Pulled off restarted the bike. Same scenario 2 more times. I stayed off the road. It starts up good. I replaced plugs, wires, cleaned and recharged the air filter. Any ideas on what it could be? The general consensus from friends is that it's a fuel issue. Any help would be awesome.
Old Jun 29, 2012 | 10:46 PM
Hopper's Avatar
Hopper
Check your fuel tank vent is not blocked.
Old Jun 29, 2012 | 10:47 PM
pontiac69's Avatar
pontiac69
Do you have a tuner on the bike?
Old Jun 29, 2012 | 10:59 PM
777's Avatar
777
Check your screws on the battery terminal and make sure they are tight.
Last night I was cruising down the freeway and lost power about three times and then the bike shut off(little bit of a pucker moment since I had to use the old fashion hand signal and pray that the cagers' saw it). Finally got it home and had about a quarter turn to make them tight. Bike fired right up took it back out for the evening.
rgrsnell21's Avatar
rgrsnell21
Ok, I'm new to bikes. I'm not sure what you mean by tuner. It has Sampson pipes and the fuel management system underneath the seat. I don't have an owners manual (I ordered it though) so I'm not sure where the vent is. I'll use the google machine on the interwebs to try and figure out where it is. Thanks guys
Old Jun 29, 2012 | 11:02 PM
rgrsnell21's Avatar
rgrsnell21
777- #1: your bike looks nasty! B: I'll check the connections and screw in the a.m. Sounds like mine did the same thing. Your right, pucker for sure.
Old Jun 29, 2012 | 11:08 PM
rooti's Avatar
rooti
Did it recently get wet or washed? Try unplugging the fuel management under the seat
Old Jun 29, 2012 | 11:11 PM
rgrsnell21's Avatar
rgrsnell21
No, no washing or water. So do I unplugg the fuel management and leave it, adjust it or what? Again, I'm new and dumb. Anything helps guys. Thanks.
Old Jun 29, 2012 | 11:14 PM
rooti's Avatar
rooti
see if you can see what brand is on it
Old Jun 29, 2012 | 11:26 PM
rgrsnell21's Avatar
rgrsnell21
Wait one...........k. It's a Terry TV3 terminal velocity fuel management system.
