11" Progressive shocks
Old Jan 17, 2007 | 11:51 PM
Bug_Guy's Avatar
Bug_Guy
Default RE: 11" Progressive shocks
They've been around since 1991.....lots of bikes have them
Old Jan 17, 2007 | 11:58 PM
vinnypie's Avatar
vinnypie
i keep seeing them on e-bay but they say 91-05 fdx.i have an '06 and i NEED them bad( i'm 5'6'). will the 11" progressives fit?
Old Jan 18, 2007 | 12:11 AM
Bug_Guy's Avatar
Bug_Guy
They changed something in 2006, but I'm willing to bet it's something minor....lots of times they'll say something won't fit, but many times it's only because of an extrra hole or a different stud, etc.
Old Jan 18, 2007 | 12:21 AM
Nach's Avatar
Nach
What I did was get the part number and go to progressives web site and see if it was on the list for my bike....sure hope they fit
Old Jan 18, 2007 | 02:53 AM
Whiffleboy's Avatar
Whiffleboy
412-4037C is the part number for my 11inchers. "B" would be the black version. I picked mine up for $107 (used but new condition) on eBay.
Whiff
Old Jan 24, 2007 | 12:20 AM
Nach's Avatar
Nach
So do any of you guys ride 2 up much? I was asking cause I figured that they would be more likely to bottom out then
Old Jan 24, 2007 | 12:29 AM
Nach's Avatar
Nach
Also did you guys change your stand as it seems to sit pretty upright with these things on
Old Jan 24, 2007 | 02:05 AM
Whiffleboy's Avatar
Whiffleboy
Although there have been a couple of times I readjusted my parking position, I really don't think it's a factor you should be worried about unless you find yourself in hilly terrain.
Whiff
Old Jan 24, 2007 | 04:50 AM
traveler's Avatar
traveler
See pic below
1 5/8 inch clearance bike jsut sitting
with me at 230 lbs, I have 7/8 inch of fender clearance through the 2-up seat mounting hole!
412 Heavy duty's from Jireh cycles, delivered at 200 bucks!
Either need a shorted jiffy stand ar have your existing jiffy stand tweaked a little in a hydralic bender.
I never bottom out. Shock come from the factory at the middle adjustment. 2-up, yea, it'll bottom out I'm sure, unless you crank them all the way down.
Joe
Old Jan 24, 2007 | 04:53 PM
waterman7474's Avatar
waterman7474
i'm pretty happy with mine. i do also think they are loosening up a little.
but if your looking for a BETTER ride two-up, an 11in probably wasn't the way to go. just for one up, going to an 11in is more stiff, two up your gonna have to dial it up pretty stiff and it is already stiff caust it's so much shorter than stock.
