To w/ pc3
Old Sep 7, 2012 | 09:59 PM
cmancini26's Avatar
cmancini26
Default To w/ pc3
I congratulate you on installing it yourself I'm very close to giving up I can't get this damn thing to fit correctly any which way!!!
Old Sep 7, 2012 | 10:13 PM
Gringoloco13's Avatar
Gringoloco13
Sounds like you are getting frustrated, trust me take a break! Go grab a cold beverage of your choice, smoke a cig if you smoke, relax and come back in 15 mins with a new mind set. You can install it, just follow the directions, route everything clean and finish up the install.
Old Sep 7, 2012 | 10:24 PM
cmancini26's Avatar
cmancini26
Yea I'm taking a break I've worked 11 days straight and keep trying to do this after work I had it perfect but realized there was a wire that looked pinch and of course I rage it apart to move it and everything moved
Old Sep 7, 2012 | 11:55 PM
annapolisfatbob's Avatar
annapolisfatbob
you'll get it! they are a pain in the ***.
Old Sep 8, 2012 | 01:11 AM
Tat2u's Avatar
Tat2u
Either just fit it under the seat, this is easiest or if you really want it tucked right down, remove the battery and battery box, fit the pc3, then reinstall the battery box and battery.
Old Sep 8, 2012 | 09:11 AM
cmancini26's Avatar
cmancini26
Well got up early this morning and it's done tucked it under the seat and all i need to do is run a usb cable because it's tight under there but it's done no more decel pop runs a lil cooler I'm happy with it
FLYINGBROKE
Audio Systems
Apr 9, 2017 07:57 PM
thelawnmowerman
Air Suspensions
Jan 13, 2012 02:11 PM
man4mopar
May 5, 2011 05:18 PM
CLYDE60
Jan 12, 2011 07:26 PM
Phurion
Jul 27, 2009 07:10 PM
