front brake light switch engagement...
Just got done wiring some new bars and putting everything back together. The only thing I don't seem to be able to get is the front brake lever to engage the brake light switch. The switch is working, when I pull the lever off and engage the switch with my finger so it's something I'm doing wrong with the install. I can't fit a 5/32" wedge in the lever, but I'm pretty close with a piece of doubled cardboard.
Any hints, clues, advice?
Did you put the cardboard in before taking them off of the old bars and keep it in until everything was back together on the new bars? If not, you need to replace the switch. If you did, you just have to be careful to get it n the right spot so the lever hits the switch. Kinda tricky and real easy to break it
