Harley Davidson Forums
Harley Davidson Forums (https://www.hdforums.com/forum/)
-   Dyna Glide Models (https://www.hdforums.com/forum/dyna-glide-models-9/)
-   -   bike won't start? 06 sbob (https://www.hdforums.com/forum/dyna-glide-models/820295-bike-wont-start-06-sbob.html)
EastBay_Solo Nov 1, 2012 12:36 AM
ok guys went to take the bike out for a ride and the bike won't start. It has a new battery so I know that's not the problem. The head light comes on but no other lights. just the N for neutral. I hit the run button and nothing, light was also going dim fast . Please chime in if you have any idea's.
PKellyMc Nov 1, 2012 01:51 AM
See if you've got any diagnostic codes; should be able to search a procedure and list of codes here on the Dyna section. Though your issue sounds beyond "codes", one of them (if present) could point you in the right direction.
stilup Nov 1, 2012 04:59 AM
Loose battery connection?
Starter relay?
ezmo Nov 1, 2012 08:18 AM
Lights dimming tells that current is getting low. Did you charge battery before starting to use it, its never full when buying it? Check the connector in front of primary case, its coming from stator. It must be firmly togehter. Thats common place to have issues with charging and power supply. If connectors are loose/dirty, they melt down.
dyna rider Nov 1, 2012 09:27 AM
Won't Start
Could also be a pinched wire from installing those handlebars..
EastBay_Solo Nov 1, 2012 09:38 AM
the battery is about a month old. I'm thinking its the stator. Its an 06 as far as codes go. I can't pull a code from it because that gauge isn't on. the only thing on is the head light and neutral indicator. and that's barley because the power is almost gone.
cee Nov 1, 2012 09:47 AM
Charge your battery all day then try again right away. Your headlight dimming is a sign of a battery problem. Even new batteries can cause problems if they have a weak cell. The jump start charger doesn't always work if the battery is NFG so that might not work. Had a battery problem with mine where it would start right after charging, wait a day or so, no start, changed battery no problems. You could also grab a multimeter, disconnect your battery, troubleshoot for a short/drain. I would check all that well before looking at other things.
07bobber Nov 1, 2012 09:55 AM
sounds like battery is low...
JRK5892 Nov 1, 2012 10:40 AM
check your fuses even with a low battery you should still get a speedo indication...
EastBay_Solo Nov 2, 2012 01:08 AM
thanks every one for the good info. I'm going to charge it tomorrow when I get of work. I have to buy a charger. any suggestions in witch one to buy?
© 2026 MH Sub I, LLC dba Internet Brands
