Fxd 2001 turn signal problem
Hi,
I wonder why my Fxd 2001 doesnt flash to right side? Everything else works just right...Could it be the turn signal module?I have narrowed out everything else and this is what i think..Does anybody have these kind of problems and the reason is been tsm? And when i turn ign.on there is a 4-6 rapid flashes from right turn signal. I dont have led turn signals. Thanks. |
Originally Posted by Sparkplug666
(Post 10666874)
Hi,
I wonder why my Fxd 2001 doesnt flash to right side? Everything else works just right...Could it be the turn signal module?I have narrowed out everything else and this is what i think..Does anybody have these kind of problems and the reason is been tcm? I dont have led flashes. Thanks. |
I dont have anykind of flashing from right side.
There is a connector from the frame wich has a male connector with six wires:Two blue in the middle(These two wires doesnt go anywhere),black on the sides and violet on second left and brown on second right,Female connector has four wires.Two black and violet and brown,these wires is connected to flashers and these two violet and brown is also connected to speedo and tsm.The brown wire is to right and the violet is to left turn flasher. I have connected the left turn just as it should be but when i connect the right side just the same way it doesnt work. |
(Post 10667101)
There is a connector from the frame wich has a male connector with six wires:Two blue in the middle(These two wires doesnt go anywhere),black on the sides and violet on second left and brown on second right,Female connector has four wires.Two black and violet and brown,these wires is connected to flashers and these two violet and brown is also connected to speedo and tsm.The brown wire is to right and the violet is to left turn flasher. I have connected the left turn just as it should be but when i connect the right side just the same way it doesnt work. Take a probe light and check if you have: 1. input from the r/h turn signal switch at TSSM pin 7 (white/brown wire) 2. output from TSSM pin 6 (brown wire) If you have input from the switch and no output at the TSSM, the problem is in the TSSM and you'll have to replace it. If you have no input from the r/h switch, the problem could be in the hand control (switch or disconnected white/brown wire or no power from the red/yellow wire) Your dealer is able to check the TSSM using test equipment. |
Okay,ill try that.
This seems to be the only thing i dont have already tested.But becose of my work and holidays ill be able to test it next year...Ill tell you then was that the problem or not. If i think its the tsm i think that my local dealer could borrow me a functional one and i can test it before i bought one. Thank you. |
I had this happen on my softail. It was the button for the signal.
© 2024 MH Sub I, LLC dba Internet Brands
