SuperGlide winter mods done!
Apes are on. Risers are on. Tank lift is in. Zombie levers are on, everything lights like it should, everything is adjusted, now just need the chrome turn signal swivels to get here, and some good weather.......!
http://i165.photobucket.com/albums/u...ps54a1628e.jpg http://i165.photobucket.com/albums/u...psfeeaed90.jpg |
Looks great. How tall are your risers? Did you have to change any cables or wiring?
Thanks!
Risers are 2". I bought a Burly cable kit for the 12" narrow apes. I needed all the cables and brake hose. Wires might have reached, but the kit came with wire extensions, so I used them. The kit was awesome. Everything fit very well. |
Looking good!
Sharp looking bike! I like that Blue & Silver.
Those babies are up there. Look good though.
i had 12" apes on 3" risers and used all stock wires and cables...i had to get a little creative .....the throttle cables and clutch cables were MAXED out!!!! all the wiring was fine just pulled it out from under the tank. i was gonna switch out cables but would up going with a very different set up ...now i have 10" risers with sporty type bars (about a 3"rise on bars) so i actually only dropped about an inch overall but all the cables are not so stressed so im good! enough about mine....YOURS is looking good!!
Looks VERY good! that blue and silver is a great color combo.
What apes are those chain? Great mods..
Thanks everyone. The apes are Burly 12in narrow bars with 2 in LA choppers straight risers. Had to put in stiff riser bushings is cause the bars moved around a little.
Randy |
© 2024 MH Sub I, LLC dba Internet Brands
