tappets and push rods
Just wondering how difficult you all think it is to replace tappets and put in the quick install push rods. Also is there a brand that I should be looking for. Its a 09 FXD. No engine mods other than high flow AC and SE slip ons. I want to change them with new to see if it helps with engine noise at start up. OEM would be fine with me unless there is a better choice. I really don't want to remove rocker covers unless absolutely necessary.
just have to pull your rockers, that is the only way to get in there unless you open them up and cut out the old ones and install adjustable... but why are you replacing the pushrods id your not doing cams?
Originally Posted by JRK5892
(Post 10920054)
What's wrong with the original lifters?
Originally Posted by Scuba10jdl
(Post 10920994)
that is just cause there is not alot of lube up there try adding 20oz of lucas oil treatment on your next change = gone... i do this on all my HD's works great!
© 2024 MH Sub I, LLC dba Internet Brands
