Fuel Tank Filler neck Recall
I decided to take a leisurely 270 mile ride today as I needed to run by the office and pick up a package. While in the Capitol City I decided to go by the dealer and get a new key fob programmed to the Dyna. While it was on the digital technician, a recall for a fuel tank filler neck came up. The dealer fixed it while he had it. Anyone know what this recall was about and where can I go to type in my VIN to see when there may be outstanding recalls that I am unaware of?
BTW new HD fob including programming $40 at H-D of Jackson MS.
I'll give you a link that you can either search for your bike by Make or year and find what recalls (if any) have been issued for your bike. Then you can contact your HD dealer, tell him what your vin number is and have them check if that particular recall was done on your bike.
Here is the link: http://motorcycleviews.com/recalls/m...clerecalls.htm
Not sure but I think the one you are talking about was a poor weld on the tank vent tube under the gas cap that would allow gas to leak out if the bike was tipped over. That would cause a fire if the engine was hot when tipped.
Hope this helps.
Hope this helps.
@ Joe
This is what I had seen about the recall
"The Motor Company is initiating a Voluntary Emissions Recall for certain 2008-2010 Softail® and certain 2008-2011 XL and Dyna® family motorcycles. Upon exposure to certain types of fuel formulations and/or high ambient temperatures, the gas cap may develop a fitment issue of the gas cap on the tank. If this condition remains undetected, it may prevent a proper seal between the gas tank and fuel cap assembly, potentially allowing fuel-related emissions to vent through the cap. The remedy is have us perform a filler neck adjustment which will take less than 10 minutes."
My 08 FXDF was affected. It leaked frequently before, but not once since
Had the dealer do the recall thing earlier this year, even though I hadn't had any problems with the cap sealing. Make sure you have a small rag with you to clean out all the paint chips that they are going to make when they run the tool in there. Earlier thread on this alerted me to be aware of that. I would've thought the tech would have cleaned them up, but he didn't.
