I decided that I'm choosing horsepower over looks
1 Attachment(s)
After spending the money and time with this new big bore kit, with Dave Mackie heads, custom throttlebody, injectors and all the horsepower tricks I could come up with the last thing I wanted Was hot air and oil and blow by back into the engine. So this is my crude attempt that will be refined in the future down to something smaller and I weld nipples onto the oil filler cap and have it all just go down back into the engine. But after a few sips of a tasty beverage and some parts laying around I am onto something.
Looks inventive! Im getting this kit to stop the oil drip! Price aint bad either.
http://i1220.photobucket.com/albums/...CSystemTCc.jpg |
I saw that before I did this and figured I can do one better with some stuff I had lying around for free. I bought the breather filter screw in thingies from DK customs Which work great but cruising at over 100 plus miles an hour pushes oil out and gets on the bike. Not something I want on me or want to clean up off the bike or want any type of oil flying around. Plus if you have an oil drip you will find that that system will not fix your problem but it just won't put the hot oil back into your air breather and throttlebody but all over your bike.
Originally Posted by Wheelup
(Post 11233852)
Well the oil that was going in the air filter assembly was still coming out and the breathers from DK (which under "normal" conditions might not) and going all over. It's gotta go somewhere. I have a Fueling ball, bells and whistles pump and plate set up and it's still coming out. At low rpm's and legal highway speeds it's not bad, but when this thing gets pumpin it's pushin oil like a bastard I guess. I've drilled out the rocker plate holes larger, replaced the umbrella valves and that fiber crap in there, stacked gaskets on the breather assembly to give it more room and all the things I do to engines and this one is still movin too much oil in the upper r's.
Well I got one coming in the mail and have a habit of breaking 3 didgits so I guess ill find out for myself. Thanks. Previously I modified my Big Sucker to vent the oil/air closer to the AIC and that worked till the casting broke on one of the filter mounting studs.
Or you could get one of these. https://www.google.com/search?q=stee...tm%3B500%3B465
Originally Posted by Hogpro
(Post 11234035)
At least it is for a fairly new bike. If its older and slobbering a lot then you will get a constant drip after a ride from the filter. Then the choices are either a catch-can plumbed in or take a pipe off the T down to the road (but not right in front of the back wheel!). |
DK Custom Products makes some pretty sick ones as well... i kind of dig your set up
I use the DK breathers, and I do get what you mean, there is a very light mist that comes out when you are really hammering on it, you do notice a bit on the throttle body, but its not messy or dripping anywhere, just sort up builds up a light film after a while. It doesn't bother me at all, it isn't noticeable and easy to clean with weekly/biweekly washings...
I'd still recommend them to anyone. |
© 2024 MH Sub I, LLC dba Internet Brands
