V&H Short Shots Mounting Bracket Failure
All,
This isn't Dyna specific, but since it happened on an FXD I'm putting it here. Basically bought an 03 FXD with 2K on the clock last October. Garage kept, stock, except for some Vance and Hines Short Shots. I'd had these on a Vstar before, they are the cheapest "name brand" exhaust you can get. Whatever, got a deal on the bike.
In getting ready to do my 5k service, I start hearing this rattle on engine braking. I take it to the wrench, and he says heat shields are broke. Sure enough a weld for the hose clamps broke off, and two more were rusted. So I run sans heatshields and wrap the pipe. A week later I hear another rattle. It starts driving me crazy until I go under the bike, and find the support bracket tearing in half from the bottom up like someone ripping a sheet of paper. You can move the pipes up and done and hence hear a squeak/rattle.
V&H offers to sell me replacement parts because I'm the second owner, never mind the pipes have 5K miles on them and look like they are one step from the Junkyard. I politely tell them that if they arnt interested in fixing thier defective product, I'm not interested in running thier pipes.
Summary: Caveat Emptor. You get what you pay for, and unless you are looking for a temporary exhuast system, I can't reccomend these. if nothing else the quality of thier metal is atrocious.
Well in hindsight, checking and maintaining the proper torque specs probably had a lot to do with the longevity of the bracket. And as far as the pipe quality goes, if you are referring to bluing or other coloration, that has to do with the heat your engine puts off, which is related to your tune. I'd make sure to check both these things when going with a new pipe so they dont fall short of your expectations... And as for VH not giving you free parts, well what company does?
wagtenor (05-19-2019)
Vance and Hines Bracket Failure
I have just returned from having my Vance and Hines Short Shot pipes replaced with Sportster 48 stock pipes. The mechanic showed me the V&H pipe bracket which was ripped exactly as you described. I have just bought the bike and it has 2K on the clock. Very disappointed as I was hoping to sell them on. Looks like I'll have to get the bracket welded or replaced.
All,
The heat shield brackets are quite frail, I'm not surprised of failure especially if you park your bike outside often overnight. When I was installing them I was already a bit concerned.
The actual exhaust bracket though is a chunk of metal that should not ever fail.
Harley1016
2014-2023 Touring Models
17
09-18-2019 05:22 PM
