I got some bad gas about a week ago pumped it out. Put fresh changed plugs took it too dealer had the clear trouble codes. Bike runs good but when i start it in the mornings it turns over about 15 to 20 seconds then starts. Check engine light comes on after running about 5 seconds then goes out after about 10 to 15 seconds after it comes on. I have a PC3 and SE heavy breather. It didn't start doing this till after i got watery fuel. Anyone have any ideas that might help me. Can you get trouble codes with out a scanner ?
2006 FXDLI
My 06 lowrider was throwing the same code and my engine light was doing the samething with going on and off. Also have a PC3. Turns out the main harness connector and PC3 harness connectors got water in them. I dried them out and put dielectric silicone on the pins and the problem went away. Did you happen to wash the bike or ride in the rain?
I don't remember the exact code I got, but it said something about the o2 sensor. Come to find out the o2 sensor was not tight. I bought an o2 sensor socket at Harbor Freight Tools, tightened the sensor, cleared the code and that was that!
