07 Street Bob detachable sadddlebags w/pics and video
Yes, the HD relocation kit is fugly.
The streetglide turn bar is close but won't fit on the fender, curve is slightly different. You need a small die grinder, little grinding. The hardest part is drilling 2 holes on fender, I just eyeball it. I tried to get mine as lever as possible, it's not that hard. If you need part number, pm me ok.
Rear light bar part # (68629-05) BRACKET, REAR TURN SIGNAL BAR
Wiring socket 73191-96, 2 required.
You can reuse the stock rear turn signals sockets and wiring harness, the length is more than enough. The socket base can be removed by prying it with a small flat head screwdriver, reuse rear turn signal lens as well.
I'm a newbie---I cant find how to pm you. or maybe basics can't pm. Did you need a new harness, or were the wires long enough? And the brake rotors are killer. I will be buying those next to go with my Heartland front fender. You did a great job, I'll find a way to post pics of mine. Thanks
