Harley Davidson Forums
Harley Davidson Forums (https://www.hdforums.com/forum/)
-   Dyna Glide Models (https://www.hdforums.com/forum/dyna-glide-models-9/)
-   -   06 lowrider won't start. (https://www.hdforums.com/forum/dyna-glide-models/884533-06-lowrider-wont-start.html)
chrslefty Jun 21, 2013 09:10 AM
Hi guy would appreciate your help.
I have a new to me 06 .
The bike sat for about a year a was started intermediate. I got her home and on the charger and was able to get it fired up and seamed to be running fine. We to go get some gas and it cut out on me right wen I got to the pump. Might have been user error. And hasent worked since.
Any ways, I hear the pump prime. And I put in a new battery . But it just turns over but won't fire up . Im getting spark. But the plugs are bone dry. And no codes are showing up. I did try pinching the fule line after the prim. I was able to pinch but it was pretty firm.
Thoughts?
Thanks for your help.
chrslefty Jun 22, 2013 12:36 PM
Bump.
Thanks for looking.
nhrider1 Jun 22, 2013 12:55 PM
Thoughts?
Sounds like it's not getting any gas. Bike sat for a year. The gas probably went bad...turned to varnish or other ugly stuff. I'll bet the fuel line or injectors are blocked...most likely the injectors.
I'd drain the tank. Clean out whatever fuel lines you can get to and check the pump filter. Don't know if you can clean the injectors with a solvent to clear any blockage, but I'd try. Worst case you may have to replace the injectors.
seniorsuperglideE8 Jun 22, 2013 07:05 PM
+1 on draining your fuel tank, put in fresh fuel with some Sea Foam, if you can pull your injectors and soak the nozzles in some Sea Foam. Ethanol will separate itself chemically and really mess up some fuel systems. If the bike is going to sit for any length of time it really needs to have the fuel treated.
chrslefty Jun 22, 2013 08:16 PM
Cool thanks guys ill give it a try.
chrslefty Jun 28, 2013 01:28 PM
Well I drained the tank and soaked the injectors. Put some fresh gas in and she fired right up.
Sharpie Jun 28, 2013 06:12 PM
Glad you got it running. Gasoline will actually start to seperate and do crappy thngs to an engine in less than 6 weeks. Anytime you get ready to use something that has been setting up, its best to drain the old fuel and put in fresh fuel. Small air cooled engines on weedeaters, chainsaws, etc... have this common problem. On them I try to dump the fuel out of the tank when I am finished and then run the engine until it runs out of fuel. For your bike I suggest you run a fuel treatment such as Sea Foam or Techron on a regular basis. In times when youwill not ride as ofton such as in the winter, Fill the tank with fresh gas and a fuel stabilizer for ethanol gas and run the bike for about 5 minutes to all the sabilized fuel to circulate through the pump and injectors. Stabilizers generally work for about 6 months depending on temperatures.
Ethanol (Alcohol) attracts moisture and causes rust and other problems.
nhrider1 Jul 6, 2013 08:08 AM
Glad you got everything squared away. Now go out and enjoy it. You should be good to go from here.
chrslefty Jul 6, 2013 09:56 AM
That's what im trying to do.
So I was thinking about running so sea foam through it also. But im not sure if it will be a issue with a motor that has been warmed over . The injectors had some build up around them but the spray nosels looked good .just wondering abot the combustion chambers. The motor has 11000 miles on it.but has had some recent head work done to it .
Sorry long night at work .
Here's a pic of the scooter.
Short verison seaform yea or nay ?
http://i99.photobucket.com/albums/l2...ps6813a092.jpg
nevil Jul 6, 2013 11:59 AM
Use the Seafoam in at least one tank of gas, if not 2 tanks, it can only help. Since the bike was sitting it will work in places you can't see. Ride it fairly hard unless you do that anyway.
BTW, nice looking bike!
© 2026 MH Sub I, LLC dba Internet Brands
