Relocating Dyna turn signals
I see relocation kits all over the place but they point only go up to 2007. I want a simple one like the Drag Specialties so I can reuse the factory bullets.
This is the type I like http://www.cruisercustomizing.com/fr...t/DS-2020-0372 I like the tucked in look, need it for a 2013 FXDC Appreciate any help. Thanks |
Are you looking to do this for detachable hardware?
There's a bunch out there, hopefully someone will come along shortly and give you exact models. While I can't help with that I can give you some pointers on wiring up your signals after you move them.
If you do move them and you don't do the harley kit at least search online and get the instructions for your year of bike. Anything before 2012 is going to be different wiring. For your bike you are going to need to actually cut the wires at the grips and then use some dual wall heat shrink to seal up the remaining ends and tuck them up in your housings. There are right and left pig tails in your back bone that you can pull out and reconnect your signals to. They already have the connectors on them. When I did my fronts (didn't reuse my bullets, used joker machine) I just went to harley and got the proper terminals and connectors. That way I was able to plug my new signals in and can easily unplug them if I need to. You could also just cut the existing pig tails off and then wire your signals up directly. |
Originally Posted by socialoutcast
(Post 11466405)
Looks to me like he is talking the fronts.... |
Sorry, should have clarified this is for the front.
© 2024 MH Sub I, LLC dba Internet Brands
