S&S cams.
Old Aug 24, 2013 | 01:23 PM
TwelveHD's Avatar
TwelveHD
Default S&S cams.
Hey there everyone.. Doing a little research, and wondering who is running S&S easy start chain drive cams in their dynas.. Opinions, install, grinds, etc.. Looking to put these in a 96 stage 1, and PV tuner.. Thanks-
Old Aug 24, 2013 | 04:19 PM
HD Pilot's Avatar
HD Pilot
I have been looking at those 570s and 585s, should be good on a dyna with headwork.
Old Aug 24, 2013 | 04:51 PM
TwelveHD's Avatar
TwelveHD
Yeah.. Both of those look great, but don't plan on doing any head work.. Yet.. Lol. I think I'm looking for a nice balanced cam.. That's good all the way through 4500 rpms
Old Aug 24, 2013 | 05:33 PM
Crazy's Avatar
Crazy
I know they're not S&S, but my Andrews 48's are still making 95 ft/lbs at 4500 rpm. No headwork, just an intake, V&H slipons on stock headers, 030 head gaskets and TTS on a 96 incher.
Also, if you go to the Engine/Fuel/Intake/Exhaust section of the forum, you'll find TON of info about cams, and pretty knowledgeable guys to answer your questions.
Good luck with whatever you do.
Old Aug 24, 2013 | 05:40 PM
Tat2u's Avatar
Tat2u
583 if staying at 96 and no head work, I put in 585's but went to 106ci.
It's awesome !! Great product, the easy start feature works flawlessly
Old Aug 24, 2013 | 08:19 PM
HD Bobber's Avatar
HD Bobber
Do you know if you need and new cam plate when installing s&s gear drive 585 cams?
Old Aug 25, 2013 | 12:43 AM
dirtdobber's Avatar
dirtdobber
Yes it is considered needed.
I used the SE cam plate with gear driven SS585 cams. I would check the run out before hand.
I am also using the SS585 chain drive cams in a 106"
For me The SS585 cams are a good over all cam in the Dyna bikes. With good head work These cams will be arm stretchers.
Personally, talking about me-not someone else, I would save and do head work and bore it out to 103 at least, at the same time.
106" stage 3 head work and SS585 cams
113" stage 4 heads, SS585 cams
But that is me.
Old Aug 25, 2013 | 08:01 AM
HD Bobber's Avatar
HD Bobber
Do you have to have it? Why? Is it needed for gear, chain or for both when using S&S ez start cams.
Old Aug 25, 2013 | 04:40 PM
Tat2u's Avatar
Tat2u
Don't know for the gear drive, I have no experience with them but its not needed for the chain drive.
Sharkman73
Exhaust System Topics
18
Sep 4, 2012 08:40 PM
dbrown5
Dec 13, 2011 06:17 PM
dg7080
Sep 11, 2007 08:12 PM
dhutchison
Aug 1, 2006 01:41 AM
Meathooks
Jan 23, 2006 07:53 AM
