21" vs 23" Front Wheel FXDWG
Old 09-25-2013, 01:33 PM
Sweed's Avatar
Sweed
Sweed is offline
6th Gear
Default 21" vs 23" Front Wheel FXDWG
Looking for an aftermarket wheel for my 08. Entertaining the idea of ordering a 23". I saw LooseNoose has one, looks bad ***. Anyone else done this? I am running progressive 11" shocks for the rear. Is it possible to run wider front and rear wheels?
Old 09-25-2013, 09:01 PM
wwiiavfan's Avatar
wwiiavfan
wwiiavfan is offline
Received 1,097 Likes on 489 Posts
pm me if you pull the trigger and want to get rid of your stock 21". I may be interested.
thanks
Ken
Old 09-26-2013, 02:44 AM
trainedkilla's Avatar
trainedkilla
trainedkilla is offline
When you order an aftermarket 21 or 23", it will probably be 3.5" wide. So, yes it will be wider. My RideWright 21" is 3.5" and looks a WHOLE lot better than the stock 21" (too skinny).
As for the rear, without a kit, you will need to stay with the stock width.
Old 09-26-2013, 09:09 AM
Jacoblb's Avatar
Jacoblb
Jacoblb is offline
For the rear it depends on what you have now. I have an 18"x5.75" but only 180 tire. On a wg you should be able to fit a 200 no problem. Oh yeah my vote goes for a 23" in the front. If you do go with a 21"x3.5" front, get a 140 tire.
Old 09-26-2013, 10:59 AM
Warp Factor's Avatar
Warp Factor
Warp Factor is offline
I'm working on a 23" too. So far, for a chromed aluminum wheel, Colorado Customs offers just about any of their styles (3.75 wide) as complete bolt-on which will work with your stock axle and spacers and brake rotor, for about $1600. No need for a bunch of dinking around. They can also furnish it with a tire mounted and balanced for about $250 more. No fender, that would need to come from another supplier.
On my 2006 WideGlide, I can just slide the fork tubes up in the trees to compensate for the 1" increase in ride height. Don't know about other years.
I believe I also have a little of the rake in the trees, which might help keep the front end geometry from going too far out of whack. Don't know about other years on that either.
Old 09-26-2013, 11:07 AM
Hogpro's Avatar
Hogpro
Hogpro is offline
Former Sponsor
23's are 3.75" wide. 21's for the front either come in 2.15, 3, 3.25 or 3.5 depending on brand.
Old 09-26-2013, 11:36 AM
Warp Factor
What tire would you recommend? I'd be looking for something that doesn't spread out too flat on a 3.75" wide rim. Would like to keep some sidewall height, and reasonable profile curvature so there's something to run on when cornering hard.
Mike~B
09-01-2017 01:04 AM
beau1981
09-04-2013 09:10 PM
Griff012FLHX
11-30-2012 07:39 PM
nachserv
02-07-2009 07:54 AM
bobbsterkid7
04-09-2008 12:54 PM
Quick Reply: 21" vs 23" Front Wheel FXDWG
