Torque Spec's
I am planning on taking my front rotors for my Fat Bob.
Anyone here have the Torque Specs for the following bolts. Planning on buying a manual soon. Dealer has them back order. Axle Bolt Calipers Bolts Rotor Bolts TIA |
2014 Dyna Service Manual
All from the Fastener Torque values from the front of the service manual. Im at lunch and dont have time to look into it further. this is how they are referenced in the book tho. Axle Nut Front 62-67 ft lbs Caliper front mounting bolt 28-38 ft lbs Brake pad pin/bridge bolt, front caliper 15-16ft lbs brake manifold fastener 36-60 INCH pounds dont see rotor bolts referenced... |
Don't know if this will help or not but my '010 manual lists rotor bolt torque value at 16-24 ft-lb.
Originally Posted by rgr357
(Post 11873389)
Originally Posted by O-Town D
(Post 11873639)
~ Thanks guys. |
| All times are GMT -5. The time now is 12:54 PM. |
© 2026 MH Sub I, LLC dba Internet Brands
