88 to 95 is it worth the money
Hi All, recently had my motor (02 carb'd) rebuilt due to a bad cam bearing, I didn't have the money for the 95 kit but did have a 203 cam installed with the SE hyd tensioner kit, my question is would a 95 big bore kit make a big difference, I can't afford to do the heads just the 95 kit with my SE 203 cam, looking for reliability so thinking of going with stock compression pistons, what are your thoughts
Received 4,283 Likes
One of nicest benifits to a BB is bringing the compression up for cams that need it - that way you get two benifits for the effort. But if your cams don't need it or you are not going to raise the compression for whatever reason then the benifits are reduced. If you were to do the mod yourself, then it is pretty affordable and might still be worth the effort. Paying some shop to do it - not sure it it will be enough reward for the $$$.
Sounds like you have answered your own question.
Just ride it and enjoy the ride.
You can have cheap, fast, or reliable, pick 2 is what i was always told... i have a 95' in mine, did the work in house so saved some good money, my buddy chad helped me as he went to a 107 NOS on his so i got the jugs and pistons from him, saved me some $ and i went full out, replacing the main with a lefty and welding and true'n the crank as well
Karsten
Exhaust System Topics
22
06-12-2010 02:02 PM
