Width of lifting points for dyna motorcycle Jack?
I have read the the threads on moding the sears red jacks-lifts.
But what is the width of the lifting points needed on a dyna? I have read in one post the Lowes Jack without any mods, but want to know the width of the lifting point when I start shopping for a lift. Thanks |
On my '010 FB width of frame at front is 10-1/2" - towards the rear the frame starts at 10-1/2" near the jiffy stand and tapers down to 9" under the oil pan. Your measurements may vary slightly - you should take a look underneath and measure to confirm.
Thanks for your reply. But maybe I misunderstood, or didn't make my question clear.
What is the width on the lifting points on the Jack? I am looking at jacks-modding a Jack and want to know how wide the lifting points need to be for a dyna. |
I did the sears jack last night but I just went by trial and error. I just added washers as spacers until I got the right width. I can measure it later.
Originally Posted by dmoe0826
(Post 11990859)
Pics? |
I just use a floor jack for my `09 Dyna. Along with that I use a 1 x 12 board, and two 4 x 4 x 12 wood blocks. I raise the jack high enough for the 4 bys to go under the frame just behind the trans & engine oil plugs. You just have to be careful when first raising the bike to be well centered on the 1 by, so the bike won`t tip. Once the jack is lowered for the frame to rest upon the 4 bys, the bike is rock solid for whatever you need to do.
Here's mine...I'm going to look for 7" bolts next time I'm at my local hardware store because the left side could stand to move out just a touch more and the 6" bolt doesn't have enough threads left on it.
Looking at the width between the pads, add 2&1/2" for the tape so, right around 13&7/8" http://imageshack.us/a/img89/3930/ln5p.jpg http://imageshack.us/a/img545/5007/q1wb.jpg http://imageshack.us/a/img20/561/mvsu.jpg http://imageshack.us/a/img23/5483/xot5.jpg |
Mine is 15.5" from inside to inside of the lift after the modification of Sears Red Jack. Make sure that you use a grade 8 1/2" bolts.
Originally Posted by 99%r
(Post 11990583)
(Post 11990583)
Thanks |
I will just get the Sears Jack and do the mod
© 2024 MH Sub I, LLC dba Internet Brands
