I had one on my Fatbob for a while. It was reliable and accurate while it lasted (about a year and a half). Then the display quit working. I can't remember whether it was the temperature or the oil level. Regardless, I took it off and replaced it with the stock unit this last summer.
I bought one used off a member...cost me like 75 bucks i think shipped...mine works fine and is accurate...however i was aware of the risk of it not working prior to buying it and decided even if it stops working it looks better than what i had...
I have one and have heard lots of complaints. Sometimes, my display goes blank (which they admit can happen if the unit is exposed to direct hot sunlight). I thought mine was broken, but I took it apart, pulled the battery, re-installed the battery and reassembled, and it worked. This has happen about 3 times in the 18 mos I've had the unit. Other than this tweak (twerk?), mine works fine and is accurate, and I actually love it. My bike runs hot---maybe because of the engine mods and compression boost, and I love to monitor cylinder head temp (w/ my PowerVison and see how this relates to oil temp. I added FCS cooling fans to my bike it in runs 80* cooler which has taken lots of worry out of my riding.
