Adjust footpegs??
Ok, so I'm quite ignorant with this, but how do I adjust my footpegs? I bought my bike a few months ago and would love to adjust the footpegs (Kury swing aways), which are comfortable but the angle is not ideal. I didn't see a "quick" way to do this, but what do I need to do to tilt the angle of them so my feet are sligjtly more flat.
Anything helps guys! Thanks! |
Remove the bolts/nuts holding the footpegs to their mounts and take the pegs off. Inside the mounts you'll see the bolts that hold the mounts to the frame (they are either hex or torx head bolts). Loosen those bolts and you can rotate the mounts to the angle you want then tighten them back down and put your pegs back on.
© 2024 MH Sub I, LLC dba Internet Brands
