Help with ground terminal in turn signal housing
Anybody have a tip on how to remove the ground terminal from the socket housing inside the turn signals?
Thanks, Jon |
Originally Posted by ScudRunner
(Post 12269451)
Thanks, Jon |
For the front: push the retainer tab and pull the black (ground) wire...
http://imageshack.com/a/img585/3895/4c0k.jpg Go here for some info on how to extract the fitting from the housing. |
Rear in this case. Mine don't look like the pic you posted. Thanks, though.
© 2024 MH Sub I, LLC dba Internet Brands
