Gas tank removal Question
I want to pull the gas tank off my 06 Steet Bob to install some new handlebars. The question I have is when i pull the quick disconnect off the gas tank is their a check valve in the tank that prevents the gas from leaking out of the tank? The tank is full from winter storage and i dont want to drain the tank. Any suggestions?
Do you have a cross-over line under the front of the tank? If you do, there is no check valve on the cross-over and it is a pain to remove the crossover without spilling gas. You are suppose to drain the tank into another container when the crossover tube is removed.
There is a check valve for the pressurized fuel line on the left side of the tank. I think you are suppose to alleviate the fuel pressure by removing the fuse for the fuel pump and hitting the start button briefly before disconnecting it.
Why do you have to pull the tank for new handlebars?
You want to run the engine and pull the fuel pump fuse until it runs itself out of gas. Then you can disconnect the quick connect, cover the top of the heads with a towel (or you will the heads will get scratched with the clamps on the crossover), take out both tank bolts, and slide the tank back a few inches. This will be plenty of room to get to all the wires...no reason to take off the tank completely.
Just pulled my tank on my 14wg. I got a gas can ready with a long funnel and made sure the short fuel line would reach the top of the funnel.. just used a piece of bailing wire to hold it in place after disconnecting the fuel line. My tank drained 95% of the fuel that way. Took some time tho, think I left it for about 2 hrs. I then clamped the crossover line on each side and cut. After that pulled the tank & moved it around till I drained the remaining from the crossover lines. (careful it will still leak out of the fuel line, at least mine did)
All in all didnt make much of a mess and it wast that bad. Before removing the tank to have a piece of cardboard or such over the rocker covers so that if you have to set it back down (after removing the bolts) to not damage & have a place ready to set it down.
Yeah me too on the spilled gas while doing the tanklift, even though I syphoned all the gas I could out.
