handlebar switcheroo
Is there a good substantial reason why I should just go ahead and solder them straight up or do you think my idea will work.
Also, what gauge wires are the wires going to the controls through the bars?
I did see a kit at J&P but I want the smallest most flexible pin setup, one that will not come apart. So I thought I'd check here for some direction....
just helped with some internals yesterday on o4 dyna, if ya drop the rear wheel there is a inspection cover that lets you get to the frame wires. The one we did was zip tied and would not pull out untill they were cut.
