Forward Control/inner primary cover(HELP!)
3 Attachment(s)
Hello there, new to the forum and have been getting most of my ideas and information from the site. I ran into a problem and was hoping for some insight. I have Kuryakyn forward controls installed on my 09 Dyna and now am trying to add a Kuryakyn chrome inner primary cover. For some reason the linkage hits the chrome cover and I am unable to shift. I tried to adjust the linkage but no luck. Has anyone had any experience with this. Without the cover, there is just enough clearance. Any advice would be appreciated, thanks.
Attachment 368084 Attachment 368085 Attachment 368087 |
Can you connect the linkage rod on the outside of the shifter upright arm..so the linkage falls more inline with the groove that I see on the top of the inner primary? Looks like the linkage is about a 1/4 to 3/8 of an inch to close to the cylinder heads from the photos.
I went out and looked at mine (not Kurakyn) and the linkage is well above the inner, at least an inch, and it's also connected to the inside of the arm?? Good luck! |
1 Attachment(s)
Looking closer at your pictures I question what I thought was a groove is actually a reflection of the shift linkage rod, so I did a little research and found the following info.
I wonder if the shifter upright arm should be turned the other way...see the illustration. Otherwise, the instructions are kind of vague but maybe they will help, follow this link: https://www.denniskirk.com/dk/pdf/in...5/dkh57644.pdf |
Ya It won't let me view your pic becaus I am a new member. I tried attaching the front of the linkage to the outside of the lever but it is on too much of an angle. For some reason the linkage is not high enough and it hits the cover. I cannot move the lever any further back as the shift linkage is at its shortest. If the linkage was raised up higher it would be fine but where it connects at the gear it is too low.
I called Kuryakyn tech support and they are at a loss. They just say that it is the right part and that it should fit. I am taking the bike into a shop to have a 21x3.5 wheel put on however I don't want to have to pay $85 an hour to have them look at something that should be simple job. Nice bike BTW |
© 2024 MH Sub I, LLC dba Internet Brands
