07 mags on 07 street bob
Hey, would 07 mag rims off an low rider be a direct fit for an 07 street bob with wire rims? I know every thing is the same but the front rotors looked different. Would I have to change the front calipers?
everythings the same except the front rotor... caliper is also the same
Originally Posted by SuperFastGlide
(Post 13031257)
just need front rotor, and rotor bolts/spring washers |
I measured the diameter of both front rotors (both mag and spoke rotor) and they both seemed to be the same. I got both at 12". Am I missing some thing, or should these be a direct fit. I really like the front rotor on the mags. Reminds me of dirt bike rotors.
The difference between the rotors, is the way they mount to the wheel. On the spokes the rotor uses a small 5 bolt pattern that mounts to the hub of the wheel. On the mags, it uses a big 5 bolt pattern, that mounts to the spokes of the wheel. That is the reason for needing a different rotor and mounting hardware, when converting to mags.
(Post 13066824)
thats what i said
© 2024 MH Sub I, LLC dba Internet Brands
