clutch upgrade with can change
I had an energy one extra plate kit I put in my sporty. 15% over wasn't bad but sitting at lights sucked after while. Every time I would hit neutral light turn green :$.
Looks like I have to buy a different spring compressor to do it. So they don't run riveted steels on the newer big twins I take it?
They are in and all is well, never really noticed slipping before Steve dynoed it and none now. Need to put a few more rides on them to get a better feel for them. Planning on a short thread on the install along with the Baker manual I put in.
After searching some specs and few inquiries I am leaning toward Andrews 37h grind. The lift is a little high but seems good for my stock compression. The other Andrews 26 may be better for low torque but would like the upper band to pull well. So these 3 are my choices and the Andrews are a but cheaper but still a good cam.
I put a crane 310-2 505 lift cam in my 96 ci street bob . I changed out the clutch spring for the S.E. unit. Best 30 bucks I have ever spent . Clutch engagement way more positive now. If your going to do your cam , you might as well spend the extra 30 bucks and get a better clutch spring. It was a little stiff at first but I don't notice it at all anymore. Really enjoy the positive feel of the clutch engaging now.
