remove 03 dyna electrical enclosure
Old 07-29-2014, 05:44 PM
apetterez's Avatar
apetterez
apetterez is offline
Default remove 03 dyna electrical enclosure
I figured it would be as simple as unscrewing the 4 bolts with an allen key. However it seems as tho they just keep spinning forever. Maybe they are really just that long and I needed to continue? Or is there something more to it than what meets the eye?
Referring to the cover under the seat next to the coil cover with the 4 allen head bolts.
Old 07-29-2014, 06:30 PM
bobnehoc's Avatar
bobnehoc
bobnehoc is offline
Not sure about 03 but the 4 Allens on my 07 are there for show. You just pull the cover off, no need to remove any screws. Like I said though mine is an 07 and 03 might be different.
Old 07-29-2014, 06:34 PM
jmb79's Avatar
jmb79
jmb79 is offline
I can confirm that on my 2005 Dyna, the cover is removed by pulling it off, just like bobnehoc wrote. Unscrewing the bolts (or turning them endlessly) will not work.
Old 07-29-2014, 06:38 PM
donr101395's Avatar
donr101395
donr101395 is offline
It just pulls off.
Old 07-29-2014, 07:53 PM
seniorsuperglideE8's Avatar
seniorsuperglideE8
seniorsuperglideE8 is offline
Received 4,280 Likes on 2,348 Posts
Hold on by four studs pressed in to four rubber grommets, before you push that cover back put a dab of pet jell on the studs for lubrication, next time it pulls off real easy.
Old 07-29-2014, 10:25 PM
jmb79's Avatar
jmb79
jmb79 is offline
I'm not trying to be smart *** but what is pet jell?
Old 07-30-2014, 07:18 AM
Mascman's Avatar
Mascman
Mascman is offline
Maybe petroleum jelly?
I wouldn't bother with that though...don't really want it to come off easy IMO.
Jimh64
04-29-2019 11:19 PM
Sparks200
General Topics/Tech Tips
06-01-2014 09:10 PM
fatrob74
Exhaust System Topics
10-19-2010 08:09 AM
Deuceandahalf
09-23-2010 07:36 PM
Adam17
10-26-2007 10:37 AM
Quick Reply: remove 03 dyna electrical enclosure
