Rear Wheel Jack Stand
I recently sold my superbike and bought a 2012 Fat Bob. I used to lift the superbike with a rear wheel stand and I wonder if I can use it to lift my Fat Bob with it. The contact points in the jack stand have rubber bumpers and fit the Fat Bob axle without issues. The thing is that I have never seen a Dyna or in fact any HD on a rear wheel stand. Would there be any problem in doing this? These stands have a weight capacity of approx. 350 kg or 750 lbs. That is the total weight of my Dyna and we are just lifting the rear portion of the bike.
Appreciate comments.
I would use with caution. If a 400lb sport bike start to go when you are lifting it, catching it is relatively easy. But catching a 700lb harley is a bit harder.
If I was to use it, I would do so in conjunction with a wheel chock to help balance the bike upright prior to lifting the rear wheel... I use a wheel chock with a low profile scissor jack all the time and the bike is stable (I do tie the front end down to make sure it's tight in the chock)...
I use a pitbull paddle stand like the one pictured, works great! i also use a under frame lift from ebay, cheap and works great!
next time i have my swing arm off the bike for powder i am going to weld some bungs for swing arm spools
http://www.ebay.com/itm/221377591201...84.m1423.l2649
drspencer
12-26-2011 04:59 PM
