PCIII map needed Dyna Street Bob 06-07
I'm running Samson Slip ons with no baffles and a AN big sucker filter stage 1 with o2 eliminators. Does anyone have close to the same set up. I have the baffles also so if you have a map for something with baffles that would be cool too since I don't know if I can take the noise of straight pipes so I might put the baffles in at a later date.
Is the AN big sucker pretty much the same as the SE stage one filter? Thanks in advance. |
RE: PCIII map needed Dyna Street Bob 06-07
Yah the big sucker is just a different brand of High Flow A/C. Damn near any pipe without baffles is just a straight Drag type pipe. So just grab a map off PC's site that is as close as you can get. Run it and in my opinion take it to be dyno tuned when you get a chance.
© 2024 MH Sub I, LLC dba Internet Brands
