Mark this thread as Unsold
Solid Softail Rear Wheel 17x4.5 for 06+ Dyna
I bought this wheel locally a few years ago to powder coat gloss black and install on the rear of my Dyna. Unfortunately I never got around to it and now I'm selling the bike.
The wheel is in perfect condition but could use a good cleaning or powder coat.
These solid Softail rear mags are the exact same size as the factory 06+ Dyna rear wheels (excluding WG).
A common mod needed to run this wheel on the Dyna platform is the machining of the axle hole. The Dyna's used a 1" or 20mm axle and the Softail this wheel came from used a 3/4" axle.
I had the machining to accept the bigger axles done professionally at a local machine shop.
The wheel includes brand new All ***** wheels bearings, rotor hardware and valve stem. You will need to reuse your Dyna center spacer.
Once powder coated and assembled, this setup would bolt right onto all 06+ Dyna's (excluding Wide Glide's).
Asking $300 shipped to the lower 48.
-Chris
-Chris
