2010 Fat Boy w/ 107", Stage II Heads, Woods TW-777 cams, 55mm TB
1 Attachment(s)
2010 Fat Boy w/Hillside Cycle 107" Big Bore, Hillside Stage II Heads, Woods TW-777 cams, HPI 55mm throttle body w/ 5.3 gps injectors, Zippers MaxFlow A/C, Vance & Hines Big Shots
looks like the pipe is hurting your build and maybe need some timing adjustments to help smooth the lines and bring it in quicker. How does it ride? You got a nice build there I am surprised the builder did talk to you about those pipes
I really expected him to call me before they handed him my bike. I had questions about using this exhaust or my Pro Pipe, as well as his opinion on my Zippers a/c. He said the Zippers MaxFlow is a great a/c for my bike and has the same one on his bike. The lousy service manager never told him I wanted to talk to him. I asked him about a re-tune and told me I would only get 4-5 more horsepower, and he is very happy with the immediate and impressive torque my engine creates. He also said that he expected a bigger dipping the torque around 2500-3000 RPMs. He thinks the bike is running great is impressive, and in a race would probably beat many bikes out there with 120-125hp. I don't race, and I don't see how that is possible. He said I shouldn't get caught up in the numbers because many dynos so are not very accurate. The service manager thinks that is the case with their dyno.
I made them pick up my bike in their box van to fix the clutch cable and straighten my steering head like they were supposed to do the first time. I told them to do a compression check, I want to see what numbers the bike produces. If the compression isn't what it should be I would think that's it would be a factor in thus equation. However, I am not expecting a compression issue, I'm just trying to resolve the situation in my own head. It's a real quandary. Maybe I should bring it to the tuner Scott at Hillside uses, I spoke with him once when I was working on my build and he tunes using wide band. |
© 2024 MH Sub I, LLC dba Internet Brands
