2017 FXDLS Bassani Road Rage 3, PV, Autotuned
1 Attachment(s)
Bit lower than I expected actually. That torque dip normal? Bike runs great none the less.
Attachment 621250 |
No that dip is not normal with the bassani pipes and 110" engine. Its the TUNE or lack there of. You Numbers might "look" low because you might be used to seeing them in sae not din
It's a base tune from Fuel Moto I have Autotuned 4 times.
Jamie has emailed me back a revised tune to try. As it was just a basic dyno day with no AFR measurement hard to pinpoint what needs to change. |
This bike now makes 95/114.... much better :)
Torque dip was fixed as well. The tuner was quite impressed with what the AT spat out, particularly in the cruise part of the map where not much was changed at all. The WOT/High load part did need some work, mostly more fuel everywhere. Timing only a very couple small adjustments made as it was very close from FM. Overall very happy, can notice a small Seat of the Pants improvement, particularly the transition from low to mid rpm where it picked up a good 15ft lb. I'll try to get the graph soon. |
© 2024 MH Sub I, LLC dba Internet Brands
