Dyno Charts This forum is for posting of your Dyno Charts. You will use a prefix to designate your Cubic Inches. When posting please include all model year, Cubic Inch and modifications in the thread title and in the body when posting your Dyno Charts.
XX-102": 2005 FLSTSC/I, 95 CI, Cycle Rama CR575 cam,Heads by R&R,MAGNA FLOW 2-1,Big sucker II
Old 06-19-2018, 07:23 AM
EL in NH's Avatar
EL in NH
EL in NH is offline
Default 2005 FLSTSC/I, 95 CI, Cycle Rama CR575 cam,Heads by R&R,MAGNA FLOW 2-1,Big sucker II
2005 FLSTSC/I,
88-95 CI, using CP pistons and stock cylinders , Stock heads ported by R&R, all machine work by R&R Manchester NH,
Cam plate and push rods = Screamin eagle
Lifters = S&S standard
Cam = Cycle Rama CR575
Exhaust = Magna Flow 2-1,
Air cleaner = Ness Big sucker II ,
Tuner = Dyno Jet Power vision with initial tune by fuel Moto = blue line,
final tune by Rob's dyno = Red line on chart
97.7 HP 111.5 TQ
Old 08-17-2018, 07:35 PM
98hotrodfatboy's Avatar
98hotrodfatboy
98hotrodfatboy is online now
Received 4,810 Likes on 3,315 Posts
That's a nice build for a 95"er... Little rich on the bottom... If you can clean that up a little you'll see a very nice difference. I'll bet you can see 110 by 2800 rpm... Could be the pipe to....nice job to all...
Old 08-18-2018, 06:31 PM
EL in NH's Avatar
EL in NH
EL in NH is offline
Thanks..I am pleased with the results . I look at the dyno results of the stock HD 114 motor and feel real good about my little cool running 95 incher..and I get 48 mpg ta boot. The fat blue AFR line was the initial tune . . I requested the first tune to be anything but lean..until I could get it on the dyno for a proper tune , and that's what I got ha ha ha.. the red line is the final tune. Was that the one your meant is fat on the bottom?
That's a nice running 96 ya got there.
98hotrodfatboy (08-19-2018)
Old 10-10-2018, 10:58 AM
98hotrodfatboy
Sorry I hadn't got back to you.. my mind ain't always here... Any ways yes on the red AFR .. I'm sure that's a wot run. Wonder what it's like at cruising...? I run a Wego III to keep an eye on everything.... and thanks for the compliment...
SJ12DS
Engine Mechanical Topics
29
04-13-2017 01:09 PM
Spud17
03-23-2013 10:11 PM
Smurfshxt
03-26-2009 01:55 PM
MiniMe
Exhaust System Topics
05-30-2007 08:02 PM
maineultraclassic
04-02-2007 12:21 PM
Quick Reply: XX-102": 2005 FLSTSC/I, 95 CI, Cycle Rama CR575 cam,Heads by R&R,MAGNA FLOW 2-1,Big sucker II
