103-113": 2002 FLTRI, S&S T111", S&S 585GPE Cams, HPI 55mm TB, 5.3gps Injectors, Fuelmoto E-Seriers 2-1
Bike is 2002 Roadglide
Engine is 2018 S&S T111"
Bore: 4.125" X Stroke: 4.125"
S&S Superstock Heads
Compression: 9.8:1
S&S 585 GPE cams
HPI-55D1-76 55mm Throttle Body
HPI-DINJ-2 Injectors; 5.3 grams per second,
Old Style SE Backing Plate w/external breathers - Exotix Filter
Fuelmoto E-Series 2 into 1 exhaust
Tuned using TTS by Gene Thomason - Gene Thomason Racing, Gardena CA
The baseline was after 900 mile break-in using PCV and Autotune with very rich target AFR.
Compression: 9.8:1
S&S 585 GPE cams
