Dyno Charts This forum is for posting of your Dyno Charts. You will use a prefix to designate your Cubic Inches. When posting please include all model year, Cubic Inch and modifications in the thread title and in the body when posting your Dyno Charts.
103-113": SE 103 Stage 4 advise??
Old 04-19-2019, 03:29 PM
DynaFat09's Avatar
DynaFat09
DynaFat09 is offline
Default SE 103 Stage 4 advise??
I had a SE stage 4 put in a couple years ago. Bike is a 2009 Fat Bob and rides great but wondering why the DYNO lines are so squiggly. Especially the Torque between 2000-2800 RPM?
At the time the Kit came with Ported heads, injectors, 10.5 compression pistons, 259e cams and 58mm throttle body. I have the Ventilator intake and Stock CAT free exhaust head with Screamin Eagle slip-ons.
Is it the tune, exhaust or ?? Appreciate the input.
Old 04-19-2019, 07:41 PM
jbarr1's Avatar
jbarr1
jbarr1 is offline
Possibly some clutch slip. Or it could be a tuning issue. No AFR line to see.
Old 04-19-2019, 08:26 PM
FLTRI17's Avatar
FLTRI17
FLTRI17 is offline
More than likely a bit drivetrain ****** (play) when the throttle was opened at the beginning of the run.
Not unusual for late model bikes, especially with Cushioned drivetrain parts.
Bob
Old 04-24-2019, 02:48 PM
DynaFat09's Avatar
DynaFat09
They did install the heavy duty clutch spring. I guess I am asking if I should ignore it or try to improve on it.
Old 04-24-2019, 08:58 PM
jbarr1's Avatar
jbarr1
jbarr1 is offline
Ask them for a dyno chart that has rpm/speed displayed. That will indicate clutch slip or not.
Old 04-25-2019, 11:49 AM
jbarr1's Avatar
jbarr1
jbarr1 is offline
Tried to edit above— should read gear ratio/ engine speed.
Old 06-11-2019, 11:28 AM
djl's Avatar
djl
djl is online now
Received 2,029 Likes on 1,498 Posts
Torque dip is most likely the pipe and the squiggles look like clutch slip. Even with the SE plate, clutch might need adjustment. Seeing the AFR line would help.
Steve Helton 2 (12-13-2019)
johnnycondo
01-10-2015 09:29 AM
harley_jeff
Exhaust System Topics
01-05-2012 09:20 AM
elroy
04-28-2011 08:33 AM
looneycanuk
11
08-31-2009 09:41 AM
Trippie
10-24-2008 05:52 PM
Quick Reply: 103-113": SE 103 Stage 4 advise??
