2010 fatboy lo
Replaced bars. Now when I apply rear brake my right turn signal comes on.
And when activate right signal brake light comes on. Need a little in site on which wires I got messed up. Everything else works fine. Thanks in advance. |
Think about it...
Originally Posted by TDC11
(Post 13453163)
And when activate right signal brake light comes on. Need a little in site on which wires I got messed up. Everything else works fine. Thanks in advance. On my 2010 FLHRC the right turn is orange/white and the brake is Red/Yellow. Yours is most likely the same. |
Originally Posted by nhrider1
(Post 13454872)
The power coming out of the R/H turn signal switch is White/Brown (this wire sends the signal to the turn signal module). The power coming out of the brake light switch (to power the brake lamp) is Red/Yellow. You will need to get back into that wiring and make sure the color codes match when you connect the wires. |
Ok
Everything looks correct. When I apply rear brake everything good. When I apply front brake no light. When I apply both simultaneously right indicater comes on.
Btw
As far as think a bout it. I've been wrenching on these things since I was 15. Believe me I've thought about it. This one has me stumped. I'm not perfect. I'm probably over looking somthing.
Exactly what was done to the wiring for the handlebar switches when you changed the bars? Does the wiring run outside the handlebars?
Nothing. I pulled the pins out of the connectors on each side under the tank. Pulled the wires out of stock bars. No splicing was needed. Ran the wires inside new bars installed pins in connectors. Plugged in.
Your description of the problem in post 1 conflicts with post 5.
Could you clarify exactly what is going on? |
Post 5 is Excactly what is happening now. When I apply front brake the light does not come on. When I apply rear brake the light comes on. When I apply both front and rear at the same time my right signal comes on??
© 2024 MH Sub I, LLC dba Internet Brands
