High beam indicator on bike won't start
I replaced the battery, as soon as I hooked the cables up the front signal lights came on steady along with the high beam indicator. When I turn on the ignition the headlight will turn on but if I switch the headlight to high beam,,, the high beam indicator turns off........ The only other things that have power when the ignition is on are the tail light and the horn if I push the button.
I replaced the starter relay and black relay, the headlight socket is not melted and the high and low beams work, but when the high beam is on the indicator shuts off.
Please help, my truck just broke down yesterday now all I have is the bike
HarleyGirl5555
07-02-2012 03:28 PM
