Going crazy--a short trip-- 99 ultra classic the rt turn signal does not lite op on dash, when you operate the turn signals they work but the oppiset side also blings very sightly. The bike has native customs led tailights in saddlebags for 2 years . Replaced module. still the same. Wires in handle bars at switches are ok. bulbs are ok.Help
ok no power to rt dash turn signal. all turn signals work but when u turn on the rigrt signal it flashes in the reab and the left also flashes slightly and also vice versa. Could it be the flasher relay in the fairing
I believe the 99 has a tsm (turn signal module) not a flasher, regardless the signal comes out of the tsm then splits off to front, rear, and dash. I would check all connectors from tsm to dash. Clean and dielectric grease. On older bikes this should be a regular mantaince.
If that does not help you need to run the wire back with a vom at each connector. I believe that wire is brown.
ok disconnected the rear turn and hooked up 2 test lites same issue when the rtturn is on the left also blinks slightly and vice versa.. which is the tsm under the seat
