DEUTSCH connectors and terminals
Does anybody have a line on where to get Deutsch connectors and terminals, along with crimping tools? Would also like to have a cross-reference of Harley PN's to Deutsch. I'm not sure, but I think Harley # 74190-98 is the terminal for Deutsch DTM "mini". Any place to get a crimper for under $200? Local dealer only stocks 10 terms. Thanks!
BTW, I did try a forum search and found a few threads containing Deutsch, but not the info I need.
Received 4,928 Likes
I made my own rear speaker harness using deutsch connectors, I found a used crimper for $30 locally. I ordered from Pacer, get a repair pack and it comes with pins, remember to order both plug and receptacle (http://www.pacergroup.net/Categories...tsch_DT_Series). If you order the regular kit you'll have to order the right pins so the repair pack makes it easier. Crimping these are really easy, get a good wire stripper like this (can be bought locally much cheaper); http://www.pacergroup.net/ItemForm.a...8-2507b3c18d6e
DTM series here; http://www.pacergroup.net/Categories...sch_DTM_Series
Here's another place;
https://www.wirecare.com/
Thanks guys. Checked local pawn and electrical stores, no dice. I found plenty of "open barrel" crimpers, even have a nice ratcheting set, already.
Here's the rub: I have worked in a H-D dealership for the last 9 years and got spoiled to the Genuine Deutsch crimpers that actually make two separate crimps at once. I have crimpers that make the "F style (?)" crimp on the stranded wire but not the "O" crimp over the insulation (I know, "**** retentive").
FYI: MSD markets a set of ratcheting crimpers with various interchangeable dies, one of which is the Deutsch dual crimp with four different wire size ranges. Sold by Summit Racing, and maybe Jeg's. $90 for the crimpers that include plug wire dies and another $42 for the Deutsch dies.
For now, I sacrificed an old pair of needle nose pliers and used the old Bridgeport mill at my new job to drill a hole in the jaws for the "O" crimp. Now every crimp is a two-step process but it got this job done. I do enough side work that I will be investing in the set from Summit.
ole_phart
01-20-2019 04:07 PM
