No power to left rear turn signal
I am getting no power to the left rear turn signal. The front left turn signal works fine. The bulb and signal work fine as i tested them on the right side. There is no juice to the amp connector. I am not sure what to look for. Could the turn signal load equalizer have something to do with it?
2008 CVO Springer |
Are you running leds?
So if you disconnect the amp connector inside the taillight there's no power in the socket it plugs into? Circuit board maybe?
Pull the equalizer out of the system and see if the issue goes away. |
Standard factory lights. Same issue with load equalizer unplugged.
I would use a volt tester and start at the socket and trace the wire back to where it is probably broken ir shorted until i find the issue. If you have a service manual with an electrical diagram that should help.
Yep, this ^
© 2024 MH Sub I, LLC dba Internet Brands
